Some pics from BIR last weekend - Reclaiming #9
I was looking at them again. I could run a 315/30/18 and 275/35/18 but I'm afraid it's too much rear tire. Stagger is 1.7". I wish they made a 285.......
Gary--quick question--did you play with your tire pressures at all to try and bias out the oversteer on the square setup? ie: Drop rear pressure a couple PSI, bump up front pressure a couple PSI?
Tire pressure adjustments can make a lot of difference on-track (as you undoubtedly already know).
Also--where are you getting your R888s?
I've been running 2-3 psi less in the rear on the Nittos. 32 cold front and 29-30 cold rear. I still burned up the center of my rears a little faster so might try dropping to 28.
tiresdirect.net for the R888s.
