Spark Plugs ?
I looked into changing plugs and found two Motorcraft listings, SP 519 and SP548 listed for Boss. Any difference between these two.
Also even though I have only 14k miles the car was built 4/2011 so I'm not sure I want to leave them in there much longer. FWIW my son pulled plugs on his 2012 F150 5.0 and with 30k found the gaps all over the place so doubt eng plant does anything but screw them in right out of the box. Noticeable improvement in how the truck ran especially at low rpm.
I don't know if 519s are even available any more. I have been putting 548s into my BOSS since middle of last year, and just put in a fresh set tonight. Absolutely compatible. I think the 548s are at least one heat range "colder" judging by the heat signatures up the threaded portion of the plugs after use.
5,237
4,227
Is their and point to going with a more expensive spark pug like the Brisk Iridium?
https://lmr.com/item/BSK-RR15YIR-8/mustang-gt-stock-replacement-spark-plugs-iridium-brisk-1116
