Speed Bleeder HELP
I guy's I just ordered some Russel speed bleeder for my 2012 Boss, from Summit R. I used a part number someone had put on a different post on TMO. Part number I used is 639540, Now I just check that part number and it seem it does not fit on my car. According to Russel I should use part : 639630. Can anyone confirme the right part number for my application.
Thanks
Stephan
FrenchBoss said:
Thanks AZ Boss .Is it possible that the number ending with 540 is for use with inserts...
I'm not certain--don't want to give you wrong information.
10mm x. 1.0 is the FACTORY thread for the caliper bleeder screws, for sure.
