Spring rates for coilovers - how much before chassis stiffness becomes weak link
steveespo said:
Just pulled the trigger on the Maximum Motorspots JRi 2 way adjustable set up. MM Deal of the day $4608 shipped. Thanks to 2012-Boss for the phone call heads up 8)
Went with 600 front and 375 rear spring rate, springs are cheap (relatively) so if fine tuning is needed or if I get big aero we can swap easy. Now the question becomes, do I get them in time to install prior to leaving for VIR on the 21st? Probably not but I am a sicko.
Woo damn! Very interested in your feedback. Been talking to Brian at HVT recently as well and may be adding their custom 2-way dampers to my set of options...
899
546
Placed my order too. I am sending in the spring rate calculation sheet to MM for help with spring selection. Wife is going to be so happy I "saved" $500 on a new set of coil overs.
JScheier
Too Hot for the Boss!
Tell Brian you want the Scheier discount ;)
He will most likely be building dampers for my GTS2 car over the winter and wanted to build dampers for my Boss... I just moved too quickly :(
I decided on Cortex 2 way front 1 way rears. Cheaper than the Maximum motorsports stuff since its only one way in the rear Jri.
500/300 spring rate. Not sure how Fillip valved them but he asked what I wanted I told him I drive it one day per week in the spring / summer / fall and track it once per month during that time.
they look super nice - no fancy strut body like the Maximum kit, but they still use the nice Maximum upper camber plates.
Not used to the ridiculous shaft diameter on the front strut it looks almost like overkill.
4,019
1,966
Great looking pieces, install should be a breeze. Shaft diameter on the JRis is massive, becauseracecar 8) let us know how they perform, what spring rates? Since the spring is on the shock out back you should need a slightly stiffer spring than usual as the lever arm of the control arms is longer than stock.
The arms race at BMO is escalating, I will have Nuclear capability in 2017, when the #21 GT 350 arrives.
http://checkja.com/images/cortex-coilovers.jp]
[/quote]
Nice
NFSBOSS said:
Jeff, very nice. Did you buy the offset front struts?
Yes, for sure.. I could not get the Cortex setup and skip one of his main unique things :)
I didn't get the ones from T&A because I could not get back in touch with Alex after the first email or two. Seeing these monsters i'm hardly worried. Thanks for the heads up on rear rates.. I think its going to be a 19mm rear bar to start.
Grant 302 said:
Does everyone see the CorteX black friday deal ad here? 10% off...and it says JRi coilovers, watts links, and torque arms!
Yeah that is a great discount if you're buying, especially if you're buying a whole kit!! A little too early for me, though.
4,019
1,966
Got my Maximum Motorsports Double adjustable JRis coil overs done this morning
Had to redo the rears because I stupidly didn't wait for instructions and put the helper springs on the bottom instead of the top and the bumpstops on the shaft instead of the frame mount. MM finally sent me the install instructions last night so I actually followed them and got the fronts on too. Tomorrow I will put the car on the alignment rack and set ride heights and camber/caster/toe.
Will have a set of Koni Yellows/MM Camber plates/ P Springs for sale soon.
