Stainless Steel Brake Lines
KNS Brakes
Supporting Vendor
292
20
Cary NC
Goodridge Stainless Steel Brake Lines
Goodridge G-Stop High Performance Brake Line race-bred street brake lines are constructed from the finest quality hose, consisting of a PTFE inner hose covered by braided stainless steel. In addition to providing a more responsive and firm brake pedal by eliminating the "spongy" feel that often accompanies stock rubber brake lines, G-Stop High Performance Brake Lines are abrasion and corrosion resistant to stay good looking for a long time to come.
Goodridge G-Stop High Performance Brake Line Kits are direct bolt-on replacements for all of the rubber brake lines in the vehicle's brake system. (Three to six brake lines are included in each kit depending on the vehicle's original design). To ensure proper fit and easy installation, hose ends and brake line brackets that match the vehicle's original equipment style are used for each application.
By conforming to all requirements of the Federal Motor Vehicle Safety Standard Number 106, Goodridge G-Stop High Performance Brake Lines are U.S. Department of Transportation certified and T.U.V. approved. All Goodridge G-Stop High Performance Brake Lines go through a 9-point Quality Assurance testing process that includes measuring tensile strength and the ability to contain line pressure to 3,000 pounds per square inch.
Goodridge Phantom Stainless Steel Brake Lines
Goodridge Phantom Series G-Stop Brake Line Kits are constructed from black poly-coated stainless braided PTFE hoses with the highest-grade stainless steel hose ends, banjos and bolts. In addition to providing a more responsive and firm brake pedal by eliminating the "spongy" feel that often accompanies stock rubber brake lines, Phantom Series G-Stop Brake Line Kits provide Goodridge's race-bred, long-term durability and performance.
To ensure proper fit and easy do-it-yourself installation, all necessary hardware is included and matches the vehicle's Original Equipment style used for each application. Additional brackets and hardware are coated for appearance and durability.
By conforming to all requirements of the Federal Motor Vehicle Safety Standard Number 106, Goodridge Phantom Series G-Stop Brak Lline Kits are U.S. Department of Transportation certified and T.U.V. approved. All Goodridge Phantom Series G-Stop Brake Line Kits go through a 9-point Quality Assurance testing process that includes measuring tensile strength and the ability to contain line pressure to 3,000 pounds per square inch.
StopTech Stainless Steel Brake Lines
Stoptech® Stainless Steel Braided Brake Lines provide a quicker, firmer, more consistent pedal response by maintaining consistent brake pressure. Additionally, stainless steel lines provide precision brake modulation, especially during threshold braking. The improvement in pedal feel is more dramatic on older vehicles where the factory rubber line may have softened and swelled due to age.
Stoptech® brake lines consist of a PTFE (commonly referred to as Teflon®) inner line that carries the brake fluid, which is then covered with a layer of stainless steel woven braid. The PTFE tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid.
The braided stainless steel provides support for the PTFE and the weave is extremely durable against incidental impact and abrasion. Next the stainless braided hose is coated with a clear abrasion resistant PVC cover for maximum protection against chaffing and strain relief devices reinforce end fittings.
A variety of end fittings are available to meet most application needs. All fittings are engineered for proper fit and durability. All necessary brackets and fasteners are included with each line kit.
Not all products are available for all models. Please use the car selector on our website to check stock. Thank you for your business.
