Standard or Metric Fasteners?
Grant 302 said:
I remember my SN95 2000 to be a good mix of both, but I only recall using the metrics on my '11 and '12?
I always grab metric first but it seems to me I've had some chassis bolts where SAE fit better. Maybe I'm wrong on that though.
But I'm happy using metric. When I was a kid and working on my motorcycles I loved the metric system. I wished the US would change over and dump the British system. ;) Anyway I'm glad to see we are there.
I haven't had everything apart in these cars, so I've been curious about what's inside the axle. The square drive plugs I guess are still SAE, but I think NPT and flare fittings will be tough to switch over.
There was a small push for metrics growing up and it's sad how it's been half-ass adopted by the federal government. Contracts are written up in metric, but everything is still just the SAE equivalent.
That was an easier time growing up though...metric for the mopeds and motorcyles, SAE for the cars.
Justin
I've taken apart many things on Ll span if the years of mustang. Get metric. Sae sizes are for fox bodies and some parts of the sn95.
Owned the following
87 gt
96 cobra
06 gt
2012 boss.
95
Metric. My matco guy barely keeps any standard stuff on his truck anymore.
pufferfish
Supporting Vendor
1,094
66
Maryland
metric is so close to sae in some sizes, that they are usually interchangeable. 8mm~5/16", 11mm~7/16", 13mm~1/2", 14mm~9/16", 16mm~5/8", 19mm~3/4"
i cant think of anything on these cars that are still english threads except lugnuts and ring gear bolts. wow, i have had WAY too much of this car apart!
jneary
Performance Fords
323
Norcal
Unless you have one of each, start with metric. I'd get a complete set of box ends up through 21 mm, sockets in std and deep wall through 21mm, torx, and nut drivers. That should cover everything that you will need for most jobs.
john
The harsh public outcry over the sale of gasoline in litres is what killed the US conversion to metric. Then again, that was a cheap a$$ fix to avoid adding a third digit to gasoline pumps...
