Steeda LCA Relocation Brackets
1,022
104
Texas
Has anyone installed the Steeda LCA relocation brackets? The instructions call for them to be welded in. If someone has pics of the install can you please post them because I couldn't find anything on the net. All the pictures I saw looked like they were just bolted in? Thanks in advance.
Quick update...if anyone installs the Steeds LCA relocation brackets you MUST weld them in. For street driving you might be okay but with sticky R compound tires on the track they moved! I took my car to the Nurburgring last weekend and they were great until I got onto the track and the rear end shifted. I had to take them off and do the weekend with the control arms in the stock location. I also have the billet aluminum LCA from Steeda...Other than that car handled like it was on rails.
The Ford Racing relocation brackets do not need to be welded unless you're doing a lot of drag racing. That said it's probably not a bad idea. Mine are not welded on and no issues so far.
