Tucson 302
2013 Black LS #439
Any 2013 owner changed out the steering wheel for a racing wheel? If so without the buttons that are on the wheel is there a way to clear the warning messages that pop up?
skwerl said:There is an 'ok' button on the radio as well as on the steering wheel. Press the center of the right side tuning knob.
06mach1 said:Last I knew if you replaced the wheel with a race wheel, you will need to remove the clock spring, which contains the steering wheel position sensor. Once you loose the position sensor you will have all kinds of advance track issues. The way to resolve that is with the ford racing abs module.
