CaliMR said:It is the same block as the GT, so those should probably fit.
When you switched to DOT 4 did you flush all the DOT 3 from the clutch hydraulic system? I would assume you would need to remove the clutch hydraulic line from the slave cylinder to do this (right?).bolecailey said:I was on DOT 4 already. Most of us are already.
bolecailey said:I will probably take it to the dealer eventually but I am hesitant since it seems like there is no real fix outside of moving to an aftermarket clutch. I would love to have Ford fix it, because it is clearly a defect with the number of people who are having these problems on the 2011+ cars with the MT-82 transmissions. It just seems that there is no real fix for it without going with an aftermarket clutch.
YellowJacketBoss302 said:When you switched to DOT 4 did you flush all the DOT 3 from the clutch hydraulic system?
Still..... "enquiring minds want to know". Many are using DOT 4, but I haven't seen anyone directly confirm for sure that they have DOT 4 in the clutch sysem. Actually, Scott, you might be one,though. When you had the clutch replaced did they fill the system with DOT 4?2012YellowBoss said:YellowJacketBoss302 said:When you switched to DOT 4 did you flush all the DOT 3 from the clutch hydraulic system?
There should be no reason to bleed the clutch system fluid. It will not get hot enough to boil like the fluid in the brake calipers.
2012YellowBoss said:You should take it to the dealer even if they do not fix it right away. Ford will not use resources to find a proper fix until there are enough reports of the problem. Also if this causes system damage down the road you will have a record of the problem documented with them.
YellowJacketBoss302 said:Still..... "enquiring minds want to know". Many are using DOT 4, but I haven't seen anyone directly confirm for sure that they have DOT 4 in the clutch sysem. Actually, Scott, you might be one,though. When you had the clutch replaced did they fill the system with DOT 4?2012YellowBoss said:YellowJacketBoss302 said:When you switched to DOT 4 did you flush all the DOT 3 from the clutch hydraulic system?
BossJockey said:Scott, do you know if the clutch and pressure plate were replaced with the same parts that came out of the car, or has there been an upgrade to these parts since the early builds?
How many people that track there car regularly have not had clutch or shifting issues?
