Stock springs up front, M-5300-P springs in the rear? Any issues?
I think that will work fine. You'll probably want an adjustable panhard bar to recenter the axle.
four-walling said:
Just want to drop the rear about 1 inch for looks.
I do not track the car.
Any known issues doing this?
Tanks in advance.
I know a few forum members who have done this Steeda's Boss rear springs, myself included. I'm not sure about the P-springs. The Steeda’s changed the handling, but on the street the difference was hard to notice. On the track it made the car a little looser, but I actually prefer a slightly loose condition on track. On the street the car rode a little firmer, but nothing I couldn't live with. The Steeda's dropped the rear 1 inch.
I have replaced the stock dampers and struts with some new Koni's along with the Steeda Boss springs all the way around. BIG improvement....
isrboss
OP, I would look to the BMR rear springs. You can purchase them without the fronts. They seem to have a lot of vendors stating 1.5" lowering. BMR states 1.25" and another Boss owner installed the whole set and the rear dropped 1". I would go this route if I were you since the spring rate is around 145lbs/in (GT factory) and linear. Even if you decide to do some spirited canyon carving you will keep a more understeer balance (more rear grip)
170
37
I ran the P rears and the FR panhard bar for about 1000 mi before changing the fronts.I did not go to the track,but I would have no problem with doing so.The only real change was the look,and that difference was huge.
four-walling
Kerry, San Diego
You changed out the front springs after 1000 miles because you wanted the "raked look"?
I also changed out the rear springs only to level the car.$123.00 shipped from roush. everything else came from Spohn,price and quality is top notch, with a few differant options.
170
37
I didn't change the fronts because I wanted the "raked" look.The P springs lower the front by less than 1/4".I did the rears first to see if there was a low cost alternative for lowering the rear only.I planned on front and rear springs from the start.
