Strengthrehab's Better Late Than Never Build Thread
Discussion in 'Road Racing Forum' started by strengthrehab, May 2, 2018.
  1. strengthrehab
    strengthrehab TMO Race
    273
    202
    Sep 16, 2014
    Texas
    Not yet. Removing those cam covers sucks.
    Sent from my SM-G960U using Tapatalk
  2. VoodooBoss
    VoodooBoss Rick Moderator
    20,436
    2,826
    Nov 30, 2010
    That first plug does not look good.
  3. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
    That was on cylinder 8. 2nd plug was cylinder 6 (bad one)
  4. Grant 302
    Grant 302 OPM Spent: $665,833 Moderator
    6,793
    1,719
    Nov 23, 2011
    In the OC
    Hopefully the issues are contained to that head/bank. Good luck with the repairs.
  5. racer47
    racer47 All I got left is fast
    200
    210
    Jan 8, 2017
    SE WI
    Its not uncommon for broken pieces from one cylinder to go back up the intake and then into a different cylinder. That could explain the closed plug gap. But normally you see dimples on the piston tops and aluminum speckles on the plugs. I don't see either, except for the center of your borescope pic. I can't tell what that is directly in the light. But as you said, you need to pull the head and see whats going on. Good luck.
    2012Boss302 and VoodooBoss like this.
  6. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
    Found this this morning. [​IMG][​IMG]
  7. Grant 302
    6,793
    1,719
    Nov 23, 2011
    In the OC
    That was my first guess with the zero compression. Hopefully there isn't (much) more collateral damage.
  8. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
    Gotta pull the head then order a new head, swap all springs, upgrade OPG, timing chains, tensioners and may upgrade to a ported 18 intake and stock 18 airbox.
  9. Mad Hatter
    Mad Hatter Gotta go Faster
    2,496
    1,029
    May 6, 2013
    Ouch!! Best of luck with the repairs!
  10. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
    Trying to decide if I want to save the labor cost and do it all myself.
    Doesnt seem that hard.
  11. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
    I've decided to do this myself unless something changes. My guy (rightfully so) would charge $1k just to swap the head. Ugh.
    Plan going forward is:
    1. Replace DS head (cheaper than valve job probably)
    2. Swap new springs onto PS head
    3. New OPG and crank gear
    4. New timing chains, tensioners
    5. Long tube headers.
    I was going to upgrade to a standard or ported 2018 IM, but not entirely sure yet. I can pick one up for about 230 bucks.
    ArizonaBOSS and Grant 302 like this.
  12. 2012Boss302
    2012Boss302 TMO Addict
    703
    97
    Aug 29, 2012
    Sugar Land, TX.
    I've got the tools and the Ford manuals. Just call when you are ready.
    BTW, is your tow hook in the center like mine or offset to one side????
    Grant 302 likes this.
  13. VoodooBoss
    20,436
    2,826
    Nov 30, 2010
  14. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
    Center and attached to bumper support. [​IMG]
  15. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
    Got word that my engine issue wasnt as bad as possible and I kinda lucked out.
    When the valve spring broke, the valve was apparently held tight by the retainer and didnt actually drop far enough to kiss a piston.
    Now I just have to have a machine shop check out the valve to ensure it is straight, check the guide and install factory (gen2 and boss 302 spec) springs.
    Darker holes are #8 (bent electrode) and other is #6 (broken valve spring)[​IMG][​IMG][​IMG][​IMG]
    Grant 302 and TymeSlayer like this.
  16. VoodooBoss
    20,436
    2,826
    Nov 30, 2010
  17. Grant 302
    6,793
    1,719
    Nov 23, 2011
    In the OC
    Glad it's not that serious! Thanks for the update.
  18. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
    Now I'm just trying to figure out all of the gaskets and parts to put it all back together.
  19. strengthrehab
    273
    202
    Sep 16, 2014
    Texas
  20. VoodooBoss
    20,436
    2,826
    Nov 30, 2010
    You were lucky it didn't fully fail and drop. Get your lottery ticket!
    ArizonaBOSS and JeffV8 like this.
Share This Page
