Stripped front caliper hole
Had stripped threads on both Left and Right Caliper from use of loctite. Used Timesert (16.2mm long) inserts and they went in real easy -- these are now the spare calipers in the trailer. Use anti seize on the new calipers and a slightly lower torque (you get the same clamp load with 5-10% less torque using anti seize) with no issues.
Hate to dig this one up, but it seems there haven't been a lot of (new) issues with stripping the caliper threads. I've still been sticking to locktite and the caliper threads are still taking 85 ft-lb. No visible issues with galvanic action.
Calipers are looking old and the powdercoat is peeling in the center. I'll probably retire these at the end of this fall/winter track season.
TymeSlayer
3,787
2,741
Brighton, Colorado
Must be an optical illusion because the bolt in the second picture looks like it cracked right where the loctite on the threads ends.
