Hello,
I am in the process of gathering the parts needed to do a brake upgrade and since this will be the first time I am attempting to fully flush out the factory brake fluid in this car for something better I wanted to know how much fluid is typically needed to perform this job? Also, I am curious if anyone has had their dealship do this for them instead of dealing with it personaly? I have a Motive Power Bleeder but I'm not sure if it would work with this car or not. Its probably 15+ yrs old at this point.
The Motul RBF600 fluid I intend to use appears to normally come in 500ml bottles but I'm not sure what to expect when considering how much fluid is discarded while bleeding and then still having enough leftover to fill the system. I guess I could just buy a 5gal bucket of fluid to cover me but at the price of the fluid I would rather be a little more accurate in my purchase if possible
Do you see anything missing from the list below that I should also consider? Maybe speed bleeders?
Carbotech 1521 Pads Front & Rear
Vorshlag SS Braided Brake Lines
Centric Front Replacement Rotors
Vorshlag 3" Brake Ducts/Hoses & Backing Plates
Motul RBF600
Thanks in advance
Motul RBF600
Thanks in advance
