I did my first autocross yesterday since 2019 and I'm pretty sure my first since I redid all my front suspension (the last two years are a blur). I need more front grip real bad but I'm not sure where to start. I guess mid corner grip is ok If I baby it into the corner but then as soon as I get back on the throttle it starts pushing wide on corner exit.
Here's what I'm working with.
3240lbs w/ driver
Eibach front sway bar
MM 1" rear sway bar
425lb front springs
275lb rear springs
Koni SA coilovers
Full MM front suspension with forward offset control arms
295/35-18 A052's on 10.5" wheels
0 toe
-4° camber
3240lbs w/ driver
MM 1" rear sway bar
425lb front springs
275lb rear springs
Koni SA coilovers
0 toe
-4° camber
