- Thread starter
- #21
Swiss Boss said:I think you can make the opening a little smaller. Like 5"wide and 3/4 deep.
The little mark you see by the left on the second picture is where the grille will be approximately located.
As far as the design goes, both models look good to me.
I can make the opening any size you want. What you need to be sure about is what size opening you need with the bumper cover on as my grille sits tight in the opening. Best way to measure IMO would be with bumper cover on. Then just measure from the top of the opening to the bottom edge of the hook bracket where the ledge is in the opening. Width would be also in the area where the ledge in the opening is. My grille sits tight to the edge of that ledge in each side corner and in the center.
