- 275
- 0
sadil said:Really interested in how well the install goes. The real performance of this hood will be scene after your drive around through shitty NJ for a while loll.
Also, someone else on here may be able to give you hints on letting the fiberglass cure in the sun or something along those lines. I am not entirely sure, but someone had bubbles after a paint job, and after scraping through the paint, they found the bubbles were actually in the FG.
LP Heaven said:
LS110 said:Love the look of that 302S. That was my screen saver for 6 months until I completed the hood and wing mods on mine. Are you going with the flat black as well?
LP Heaven said:Yup and the 2 outter hood pins if all goes smooth, it should be ready next wednesday or thurs. My winter mod plans is a rear seat delete with the xbrace and corbeau bar in c/o and a 6 point boss302 belt from cooltech. I'm still up in the air on new rubber.
Either the PSS or Contis - still on the fence - if anyone has experience with one or the other, chime in on opinions
roadhouse said:I say do all 4!
But if you're just going to do 2 I would go with the outside and leave the latch functional in the middle
steveespo said:Stock hood is 34 lbs, my Tiger Fiberglass was labeled as 20.1 Lbs.
