- 6,553
- 8,204
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
Spring rate multiplier.
Rate of growth with rise in temp.
effective spring rate multiplier.the "N" is for nitrogen, so what could possibly effect handling so bad that it needs to be kept track of?
come on..somebody besides Fabman!!
BTW you're getting warm
so what am I missing?dood.. so close, but what that 15% refers to effects everything you've mentioned.. spring rate, roll out, growth..
Pressure increase with temp...didn't I mention that?dood.. so close, but what that 15% refers to effects everything you've mentioned.. spring rate, roll out, growth..
With 15% Rel. Humidity, is the advantage of using Nitrogen worth it?
I need the 1st grade primer because I have no clue what the last 1/2 dozen or so posts are about.
I actually was going to say that and a Customer walked in, I'm finally finished with his job and now and it looks like I missed the party. Oh well, it was fun. Always interesting when Blacksheep is involved.Ok guys..
Obviously, the info on the tire is the distance around, which I used to keep track of, but radial tires are so consistent that it really is no longer necessary, they are almost always within an 1/8 of each other.
The wheel set that the tire is on, because wheels wear out
The set of tires, such as Sebring set 4
The " N" is that the tire has been filled with
But the 15%
It's the amount of relative humidity in the tire
I get it from my welding gasses supplier. We use it in labs so it its very clean.Holy crap. even in our dry semi-arid region where we do most of our racing... things get pretty humid.
We race from March to Dec. Too bad its so hard to get decent Nitrogen... the ones I tried in performance shops had the same temp ranges as air. Maybe time to see if we can get better stuff.
