ls110
John
I have a slow leak in my right front Conti take-off. My first session on the this tire will be tomorrow. It appears to be losing a little less than 1/2 a pound an hour. Do I dare run on this tomorrow? My pressure setting is 25.5 cold.
LS110 said:I have a slow leak in my right front Conti take-off. My first session on the this tire will be tomorrow. It appears to be losing a little less than 1/2 a pound an hour. Do I dare run on this tomorrow? My pressure setting is 25.5 cold.
YellowBoss said:That is way low for these tires IMHO. I try for about 39-40 front and 37-39 rear hot pressure on a dry track running hard. You need to bring the camber in to -2.8/3.0 as far as I have been told. I need to have some work done to get more camber since my is maxed at 2.6.
Still your pressure is way low, I would like to see a picture of the tires, the blown and the others. Are you getting more wear on the inside/outside vs. the middle? Have you taken any temp reading?
LS110 said:Below is a photo of today's blown tire. The previous tires were too destroyed after the blowout to tell much, other than the fact my installer told me the bead was intact on each of the previous. The last two failures were clearly on the inside of the tire, as this photo shows. I have not taken temp readings and need to buy a device to do this. Recommendations of what to buy would be welcomed.
wwilde001 said:Here's the info I was given from Capaldi Racing for my car with the Continental's on. FYI, my camber is set to 2.5 degrees. Start at 32 psi cold tire pressure and run 38 psi hot. I ran my car this past weekend for three 15 minute sessions with no issues.
Zquez said:Some good info in this thread. I will say though that slicks tend to leak and its perfectly normal. The side walls only have enough rubber to stick the cords together and air will leak through them. The rule of thumb is if the tires leak down more than 3 psi an hour, don't race on them. You can however practice on them as long as they don't leak down more than 5 psi an hour. You should verify that you don't have a leak in your rim if this is a recurring thing. Also, your hot pressures will vary depending on how much moisture is in the compressed air you use. Be sure to drain the water from the compressor tank before filling tires and use a nice in line water vapor filter with your compressor system.
