I have 2 questions maybe Rob will chime in too? I never thought about tire wear and what relationship that would have to tire pressures assuming we are in operational temperature of the tire carcas.
I have always used a pyrometer to determine hot target tire pressures. So my 1st question is if you have even wear accross the tire does that imply that you are indeed running the right pressures at that particular camber/toe?
I have been lazy. I take a set it and forget it approach to tuning, alignment, and tire management. I'm leaving performance on the table. So let's say I get interested in becoming something more that mid-pak backmarker. Let's take a left biased roval (autoclubspeedway). It has a few nothing right turns and the rest all hard lefts and the oval section. The LF inside tire gets the most punishment. Alignment is setup typical road course S550 Mustang GT both fronts -3.0 camber -1/16" toe out. I'm thinking I could help the wear on the LF by reducing camber. Question 2 is how much to reduce to see and maybe feel a noticible change or see a change in laptime? Some people claim to feel 0.5-1psi air pressure. I can't do that. I think I need a change of 2-3psi to feel something. I am not looking for holy grail absolutes just out to make enough change to learn something and maybe impress myself enough that this is a direction I should explore.
