- Thread starter
- #21
Noted. I did put blue loctite when I installed the spacers though. On the topic of checking lug nut torque in the paddock, I used to check before every run but someone at the track told me to check it only once before the first run when cold, to avoid over-tightening the wheel when it is hot. Thoughts on this?Lug nuts tend to loosen in service, and loose lug nuts eventually tend to let bad things happen.
With 10 lug nuts per corner instead of just 5 you've doubled the number of failure points, and half of them are not readily accessible for lug nut torque checking in paddock.
Norm
