Sesshomurai
I know this keeps coming up. But is there a good site that provides all the torque values for all the fasteners in an easy to find place?
thanks in advance.
thanks in advance.
No problem. My dealer had printed out a spreadsheet with all the front suspension torque values so there must be a way to get them in a table format from their system too.darreng505 said:Thanks bro.
lol I use the grunt system 2-3 grunts is all thats needed for most things lolArizonaGT said:Just do everything to "good-n-tight" ft-lbs, or "1/4 turn past stripped" Nm
Thanks. Wow that's a lot lower than the 85 ft-lbs for the front.ArizonaGT said:24 ft-lbs
http://iihs.net/fsm/?dir=771&viewfile=Brake%20Pads.pdf
Thanks. I'll be replacing my rear rotors and pads for the first time this weekend. I'll remove the dust shield at the same time.ArizonaGT said:Well the 24 ft-lbs is for the slide bolts that let the piston portion of the caliper detach from the "pad frame" that mounts to the rear axle assembly.
If you need to tighten the bolts that attach the frame to the rear axle, you want 50 ft-lbs.
http://iihs.net/fsm/?dir=771&viewfile=Brake%20Caliper%20Support%20Bracket.pdf
(In that procedure it says to remove the rear axle to remove the dust shield bolts but you can do this without removing the axle using a ratcheting box-end wrench and have some patience.)
NO IT'S 76 ft/lbs for the caliper bolts! 24 ft/lbs on the small guide pin bolts!5 DOT 0 said:Thanks. Wow that's a lot lower than the 85 ft-lbs for the front.ArizonaGT said:24 ft-lbs
cloud9 said:Sorry I see this has been cleared up ;D
Yea it's basically one click at a time either curled up inside the top of the wheel well or laying on the floor depending on which side of the car. Gotta get it up at least halfway to the top of the jack stands to have room. That's why I leave my track pads and rotors on all the time ;D Fortunately the rear rotors last up to 20 track days.ArizonaGT said:cloud9 said:Sorry I see this has been cleared up ;D
No, you are still correct; 76 ft lbs; they call this the "anchor plate" I guess.
http://iihs.net/fsm/?dir=771&viewfile=Brake%20Caliper%20Anchor%20Plate.pdf
TBH I can never get a torque wrench to swing enough in the wheelwells so I usually snug the bolts with a ratchet then put a wrench on the bolts and use the poor man's impact wrench (rubber hammer/mallet) on them to "torque" them.
There are two caliper bolts on each caliper so I'm not sure about front ones and back ones. You only need to remove the top guide pin bolt to change pads. You rotate the caliper toward the front of the car. You need to remove both caliper bolts to replace the rotors.5 DOT 0 said:76 lbs? No wonder I keep stripping them out.I can get my torque wrench on the front ones but the back ones look to be a challenge. Will I be removing both sets of bolts on the rear when replacing pads and rotors?
I'm hoping the Pagid pads are quiet enough to leave them on the car. Pete has guaranteed it. ;D
cloud9 said:There are two caliper bolts on each caliper so I'm not sure about front ones and back ones. You only need to remove the top guide pin bolt to change pads. You rotate the caliper toward the front of the car. You need to remove both caliper bolts to replace the rotors.5 DOT 0 said:76 lbs? No wonder I keep stripping them out.I can get my torque wrench on the front ones but the back ones look to be a challenge. Will I be removing both sets of bolts on the rear when replacing pads and rotors?
I read through this again and want to make sure I have the Brembo front wheel caliper torque specs correct. 76 ft lbs correct?ArizonaGT said:No, you are still correct; 76 ft lbs; they call this the "anchor plate" I guess.
No - Front caliper bolts 85 ft/lbs. Rear caliper bolts 76 ft/lbs.5 DOT 0 said:I read through this again and want to make sure I have the Brembo front wheel caliper torque specs correct. 76 ft lbs correct?ArizonaGT said:No, you are still correct; 76 ft lbs; they call this the "anchor plate" I guess.
