And the slide bolts are 24 ft lbs. Then what is 50 ft lbs? I'm still confused unless the 50 was incorrect.cloud9 said:No - Front caliper bolts 85 ft/lbs. Rear caliper bolts 76 ft/lbs.5 DOT 0 said:I read through this again and want to make sure I have the Brembo front wheel caliper torque specs correct. 76 ft lbs correct?ArizonaGT said:No, you are still correct; 76 ft lbs; they call this the "anchor plate" I guess.
