Track car build
Discussion in 'TMO General Discussion Forum' started by spartan, Jul 25, 2018.
  1. spartan
    spartan TMO Race
    427
    720
    Dec 16, 2017
    Michigan
    Working on my second track car. Stitch welded the body this time. It’s a pain welding where glue was applied at the factory. I’m cleaning up the welds before going to paint
    [/IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG]
  2. Kevin Guzniczak
    Kevin Guzniczak TMO Advanced
    187
    93
    Aug 2, 2017
    Grand Rapids mi
    Good start. What’s the base from?
  3. ArizonaBOSS
    ArizonaBOSS Because racecar. Moderator
    8,025
    1,518
    Dec 6, 2010
    SECOND track car, you say??
    VoodooBoss likes this.
  4. spartan
    spartan TMO Race
    427
    720
    Dec 16, 2017
    Michigan
    [​IMG]
    Yes. This is my first.
  5. ArizonaBOSS
    8,025
    1,518
    Dec 6, 2010
    Yes very good :)
  6. VoodooBoss
    VoodooBoss Rick Moderator
    19,968
    2,407
    Nov 30, 2010
    TMO likes track car builds. Good luck with #2.
  7. boss302ls
    boss302ls TMO Race
    279
    184
    Apr 2, 2018
    mid-Atlantic
    Hey Spartan,
    Curious about why you are using welds. The adhesives that auto manufacturers and even body repairs shops now use are so strong that they form a stronger bond than weldment. Have you considered using adhesives instead?
  8. byronj
    byronj TMO Addict
    1,353
    291
    Jul 17, 2012
    Bay Area
    Fire hazard, weight, paint adhesion, nobody likes adhesive....
  9. bpracer
    bpracer Mark
    422
    310
    Mar 7, 2016
    DFW, TX
    So what are you going to use this one for, a specific race series?
  10. boss302ls
    boss302ls TMO Race
    279
    184
    Apr 2, 2018
    mid-Atlantic
    Fire hazard? Manufacturers and body shops regulary use adhesives. They are lighter, cleaner, cheaper, stronger, easier to apply. Seems like a winner. Look at the photos above and see how many welds were made on the frame. Adhesives are much lighter than weldment. I used to be a professional welder on nuclear submarines. Adhesive technolgies now are more advanced than they use to be. Aircraft builders use adhesives to manufacture aircraft frames. With welding on thin materials you have to be concerned with burn through. Another drawback is welding will weaken the surrounding materials in the heat effected zone when heated to these high temperatures. IMHO a strong case could be made for auto frames held together with adhesives being structurally stronger than a welded frame.
    Eric62 likes this.
  11. byronj
    byronj TMO Addict
    1,353
    291
    Jul 17, 2012
    Bay Area
    Some of my response was sarcasm. I know it’s hard to tell from a response ona a forum... BTW, I used to repair and rebuild aircraft airframes and hydraulics.
    And yes adhesive is great for the masses and complies with federal and EU regulations, but this is a racecar build. Not your typical Camry.
    But I do have a technical question sub welder. How does a one apply adhesive underwater?
  12. VoodooBoss
    19,968
    2,407
    Nov 30, 2010
    The new FP350S and GT4’s are all seam welded. On the Boss 302S seam welding was not an option on the 12’s, was optional on the 13’s and the 14’s were all seam welded. I was told the seam welding makes a noticeable difference. If I buy a used 302S it will be one that was seam welded.
    8250RPM, The_Dead_Cow and ArizonaBOSS like this.
  13. Kevin Guzniczak
    187
    93
    Aug 2, 2017
    Grand Rapids mi
    Adhesive will allow flex. A welded joint won’t.
  14. spartan
    spartan TMO Race
    427
    720
    Dec 16, 2017
    Michigan
    I seam welded because Kohr Motorsports runs their GT4's that way. I tried to emulate the GT4. Dean Martin is a chassis engineer and knows a thing or two about how to build a good race car. I'm no expert, just doing "best practice" stuff. I get advice and many parts for my builds from Dean.
    Swine, cornercarvin, 8250RPM and 4 others like this.
  15. VoodooBoss
    19,968
    2,407
    Nov 30, 2010
    All GT4 chassis’s are seam welded by Watson Racing before being shipped to Multimatic for assembly.
    8250RPM and ArizonaBOSS like this.
  16. yotah1
    yotah1 TMO Race
    210
    256
    Mar 22, 2017
    Detroit
    I'm sure adhesives have got a lot better over time, and what was used in my 68 Cuda is dog sh*it compared to what we use today. And I agree with one thing : adhesive is cheap(er) than a fully welded body. But adhesives deteriorate over time too, stitch welds won't when done properly.
    Fred, that's a ton of work on the body, congrats!!! I'll have some for you very soon by the way :)
    And I'm jealous of that rotisserie, I need to get or build one for next winter when we'll paint the Cuda!
  17. spartan
    spartan TMO Race
    427
    720
    Dec 16, 2017
    Michigan
    Look forward to your design concepts. You can borrow the rotisserie when I'm done.
    JeffV8 likes this.
  18. 8250RPM
    8250RPM TMO Addict
    559
    154
    Jan 31, 2016
    South East Michigan
    I grew up in a family owned body shop of 45 years in business. You are correct, adhesive is VERY strong....sometimes stronger than welding. The problem with your idea though is that it’s only good when assembling panels. You can not use it on pre-existing panels.
  19. 8250RPM
    8250RPM TMO Addict
    559
    154
    Jan 31, 2016
    South East Michigan
    This isn’t necessarily true. When a body panel is correctly done with adhesive the adhering joints must both be prepared correctly and then clamped during cure time. When done correctly it is stronger and sturdier than a weld.
    Production vehicles are spot welded as they are because they are also crumple zones. Meaning spots welds are spaced apart to allow the vehicle to accordion during impact to absorb energy.
    Glue and or stitch welding is way stronger than spot welding.
    When done correctly that is.
  20. 8250RPM
    8250RPM TMO Addict
    559
    154
    Jan 31, 2016
    South East Michigan
    You don’t think welds fail or deteriorate?
    Ever hear of rust? Lol.
    I’m sure your Cuba has / had rust.
    byronj likes this.
Share This Page
