Tracked boss owner only
PeteInCT
2,848
14
Only the 'important' ones (non cosmetic):
MM Camber Plates: To increase negative camber for better handling into corners
AirAid CAI: Slightly wider power band in high RPM's.
FRPP Diff Cover: Has integrated drain plug, adjustable supports on bearing caps.
Turkey Baster: Manage potential overflow of rear diff fluid. Also switch to Redline fluid for same reason.
AeroForce Gauge: Ability to monitor multiple engine parameters in real time (primarily temps)
Corbeau Harness Bar: For 4 pt. Schroth harness system
Harnesses: New set of 2" (for Hans device compatability) 4 pt. Schroth harnesses, expandable to 6 pt.
Tires: Set of Conti Extreme Contact DW tires for wet track conditions
JLT Oil Catchers: Keeps some dirty oil from being recycled back into engine.
Redline Water Wetter: Helps manage engine temps.
Redline MTL: Increased protection for gearbox, smoother shifts (reportedly, I'll see at next event).
Fire Extinguisher: SO I'll never have to use it ;D
Brakes: Pagid pads and Castrol SRF fluid - so the damn thing can stop (vs. stock pads)
Factory: All LS options installed (Air Splitter, Brake cooling lines, Tranny Cooler)
Boss 302S Front Grille (modified): Provides more air to radiator for better engine cooling capabilities
Tires: Nitto NT01 275/35/18 all 4 corners
Swaybar: Strano Adjustable Rear Swaybar (to dial out oversteer induced by square tire setup).
Cooling: Redline Water Wetter: 3 bottles, Helps manage engine temps. Drain 36 oz from radiator prior to "install".
Brakes: Performance Friction PF01/PF97 pads, ATE Super Blue Fluid - so the damn thing can stop (vs. stock pads)
Transmission: LS Cooler Scoop
Roush-Style Grille: Provides more air to radiator for better engine cooling capabilities
Aeroforce Gauge and oil temp sensor - Monitor water and oil temps as well as read and clear DTCs
LS wing - downforce
Corsa Extremes - weight reduction, increased hp and better sound :D
Trans scoop - cool the tranny during track use
brake cooling hoses - avoid boiling the brakes or pad fade
Goodridge SS Lines - firmer brake pedal and responsiveness
DBA 5000/4000 rotors - weight reduction, increased safety and track durability
MM c/c plates - improved turn-in and increased track tire longevity
JLT Oil Separator - keep oil out of the intake
MM 4pt roll bar - to allow safe usage of harnesses, save my neck, hopefully never need it (may improve chassis rigidity)
Sparco race seat, Crow harnesses, fire extinguisher and HANS device - increased safety
Tiger Racing hood - increase downforce (reduce lift), improve cooling
302S grille - improve cooling
302S radiator - improve cooling
302S air-to-oil cooler - improve cooling
World Challenge front splitter - increase downforce
302S tow hooks - allow me to winch onto trailer if by myself, pull me out of the alfalfa :eek:
ARP wheel studs - durability and safety
Turkey Basters- Manage potential overflow of rear diff fluid
PeteInCT
2,848
14
Whoops - I knew I'd remember something else after seeing Gary's list ;D
Hahahaha I forgot fire extinguisher and turkey basters after seeing your list. List is too d*** long!
PeteInCT
2,848
14
You still have me beat! And I remind the Mrs. every day that the 'guy out west' is crazier than I am. ;D
I spoke to someone today that is doing some very interesting things with the Boss suspension. Let's just say it's what the guys who race a 302S are doing. If I go that route you'll want to follow, and then we'll both be living alone somewhere... ;D
If the damn weather would break I could just drive and I wouldn't have time to think about all these damn mods ! :eek:
ArizonaGT said:
Forgot the ARP wheel studs and Roush mufflers on my mod list!
Gary is the mod king so far! When you gonna get that 302S wing? :)
Ugh, that'd be cheap compared to Pete's suggestion :eek: My head is spinning. Yes we need tracks to open so I can start wasting money on pads, rotors and tires. Oh yea, next Friday ;D
4,015
1,959
DBA 5000/Baer 14" eradispeed rotors
ATE Super Blue DOT4 brake fluid
Brake cooling hoses
Trans cooling scoop
Torsen
Boss 302S wheels
BBK 85mm TB
Steeda CAI
Brenspeed 93 octane tune
American Racing Headers 1 7/8" long tube headers/3" catted x-pipe
Corsa Sport mufflers/GT500 mufflers
Koni Sport Yellow struts/shocks
Tiger Racing Hood
Tru Carbon rear decklid
World Challenge splitter
Steeda chrome moly radiator support
CHE aluminum front bumper bar
FRPP M-5300P 1" lowering springs
FRPP air-oil cooler kit
Redline MTL trans fluid
Cool Tech Race Red roll bar
Sparco Circuit Plus seat
Sparco 6 point harness
GT 500 alcantara shift boot/parking brake boot
Optima yellow top battery/Taylor aluminum rear battery relocation kit
Sound of Speed 3 gauge pillar/Auto Meter ultra lite oil pressure, oil temp, water temp gauges
GT 500 upper strut mounts
Hawk HPS+ pads
Drive Shaft shop aluminum driveshaft
8,496
8,493
Currently have;
1. LS brake duct system
2. LS Tranny scoop
3. MGW short throw shift kit
4. Clear bra -- everywhere
Have ordered or will be ordering
5. MM Camber/Caster plates
6. FRPP rear diff cover
7. Goodridge SS line
8. FRPP 302S grill
9. PF01 Enkei rims and R6 Hoosiers
10. Carbotech pads
Have to wait to get more, but not a bad start.
Bill Pemberton said:
Currently have;
2. LS Tranny scoop
8. FRPP 302S grill
10. Carbotech pads
How do you like the clear bra?
PeteInCT
2,848
14
How could I forget the MGW shifter !!
(add Goodgridge SS lines too...)
4,015
1,959
Brake cooling hoses
Trans cooling scoop
Torsen
Boss 302S wheels
BBK 85mm TB
Steeda CAI
Tiger Racing Hood
Hawk HPS+ pads
Forgot
Russell speed bleeders
Scott Drake hood lift struts
Sound tube delete
Rear seat delete
Lots of "sponsor decals" ;D
