- 420
- 2
Hi guys, i wonder if you can help with some input on this issue.
My Trackey works fine i need help on another persons
I met a lady Boss Owner at a show today ( bear in mind we are in the UK) who has a normal key and a trackey.
When she fires up the car with the trackey there's no message to say trackey enabled, she has also never had the "lopey idle" message come up so i was assuming her key has never been programmed.
here's the wierd bit, she thinks the car definitely drives differently with the trackey in, she also says she can tell the difference which key she is using without looking at the key first.
So, is it possible that the key is sort of working but just not showing on the display when you turn the ignition on or is she just dreaming it.
if anyone has heard of anything similar please throw a response up, personally i dont think its been programmed is there any way to check?
ian
ian
