- Thread starter
- #61
- 599
- 536
Oh no, sorry to see this Ashley. Most importantly you’re OK. That fine powered dirt is the worst kind of mess. Hope to see you back out there soon.Time for a Update.
Sunday 8-14-22 Running with Slip Angle Track day group at Button Willow, CW13.
As I hit the high speed left before Phil Hill, I felt the rear of the car get soft under compression. Around the rear came and back ended off the track at around 120mph. The car filled with dirt almost as fast as I went off. Back ended into the fence and berm.
I have mostly cleaned out the car. I have not got it up in the air yet for damage check. I'm ok, sore now but ok.
Will be at Button Willow 10/15, Sonoma 10/22 and Streets of Willow on 10/29Looks great, @Tri-bar. Documenting the progression is awesome.
If it's ready, bring it to BW for the NASA event this weekend.
Nice, I’ll be at Streets on the 29th - look forward to catching up.Will be at Button Willow 10/15, Sonoma 10/22 and Streets of Willow on 10/29
Interested to hear your thoughts after running this setup.Couple of minor changes for Streets of Willow. Swapped out the Ford Racing Anti-Squat brackets for Kenny Brown's, then did the Roll center kit with a older style panhard bar. Boss 302S lower arms, Multimatic upper.
Will do ! Running Streets this weekend. I'll get back to ya.Interested to hear your thoughts after running this setup.
Should feel squishier in back, but more hooked, possibly to the point of understeer.Will do ! Running Streets this weekend. I'll get back to ya.
Running the rear sway bar a with low roll center reduces the affect, you really need to disconnect it to get the full benefit..Streets of Willow CCW was fun. What I found out was I really don't like the lower roll center with the KB roll center kit. Put the Stock Panhard bar back on and was much happier. Didn't get the extra bite that it was suppose to have seemed less drivable IMO, on my car. Then in session 3, fuel pump/regulator problems arose and didn't get to play in the bonus rounds with the other kids. Hope to get this all sorted soon.
Ran that spring set up, changed them out now, back to the stock 600/350 springs. dropped/added the sway bar, did all the adjustments, still didn't like it. I have run the KB full rear kit and front, even the k-link. I'm just going to set it up stock Boss 302S, and just play with Damper settings. The stock stuff is robust, can take a beating and it works. Just looking for a set it and forget thing now, Did all the playing with parts and getting to the point where I just want to drive the car.Running the rear sway bar a with low roll center reduces the affect, you really need to disconnect it to get the full benefit..
Another TMO member here did the same KB RC kit not all that long ago with a rear sway bar and he didn’t like it either, that’s why I was interested to hear what your experience would be. The KB kit lowers the RC a lot. Maybe too much. But it’s part of a whole package. Lower rear roll center, raised front roll center, no rear sway bar and big springs. The KB kit uses 650/400 springs. I don’t think you can just throw the RC kit on there and go faster. On the other hand, it’s a season to taste kind of thing, even when done as a complete kit not everyone likes it.
Boss 302s is a proven package.Ran that spring set up, changed them out now, back to the stock 600/350 springs. dropped/added the sway bar, did all the adjustments, still didn't like it. I have run the KB full rear kit and front, even the k-link. I'm just going to set it up stock Boss 302S, and just play with Damper settings. The stock stuff is robust, can take a beating and it works. Just looking for a set it and forget thing now, Did all the playing with parts and getting to the point where I just want to drive the car.
