- 5,490
- 6,498
Basically the height of the sidewall, and the front tires are more like a water balloon
This sounds like a good setup for the occasional track day car.KBBOSS1086 said:If you go with 18x10's you can fit 305's. Hoosier still has some new Conti 305/660/18's in the discontinued section of their website for $200 each. The fit up front is very tight so you may want to run a small spacer if you go this route. I run 15mm hubcentric spacers from H&R and they work great.
vrinner said:I've also read that if I go with a square tire setup, I should get a softer rear or stiffer front sway bar. Possibly go a setting or two less in the rear stock shocks from the front.
Sound about right?
