- Thread starter
- #1
Scootsmcgreggor
TMO Advanced
Hey guys, curious if anyone has installed Vorshlag MCS coilovers with an OEM rear bar without interference.
Its a tight fit spacing the coilover between the axle and sway bar endlink, and with an OEM bar and OEM endlink I'm getting some pretty bad interference between full droop and ride height. I tried one of my Whiteline endlink ends from my front bar back there (the endlink head is smaller than OEM) and it looks like it will work, but if anyone can confirm one way or the other a setup that works it would be much appreciated.
I called Vorshlag and they've only run these coilovers with a whiteline bar on medium and full stiff so weren't sure about a confiuguration with a stock bar that would work.
I may find I want to step up to a bigger bar but for now want to try with my OEM bar and want to have a setup that could use it if desired/needed.
Thanks in advance.
Thanks in advance.
