- 1,172
- 2
That doesn't sound as fun as the Ecoboost monster motor.
pufferfish said:oh, and I learned how to get an accurate dipstick reading...
1) pull the dipstick out
2) let the car sit overnight
3) insert the dipstick all the way
4) pull the dipstick out and check the result
apparently, the "tube" siphons oil up and holds it there, which gives a higher than actual level.
+1302BOB said:Justin mentioned there is no "low oil" warnings on the newer Mustangs. Why on earth would they discontinue that feature????? Oil is the life blood of any engine!
WinterSucks said:Not trying to get off-topic, but it would be beneficial to all, I think, if we cobbled together a "track use" maintenance schedule for us inexperienced guys. I always go through a quick checklist, and oil level is on there, the night before. Mostly gear checks and a quick walk-around for the obvious items.
The Boss is getting more people on the track for the first time than any other vehicle, besides the Miata maybe, and that might be why some of us are having problems with reliability. We are inexperienced and might miss the maintenance that is normal for track use, like suspension bolts/hardware, but abnormal for the street.
four-walling said:My owner's manual shows an "engine oil" warning light.
GottaBoss said:Well that's a bit of a relief. I wonder if that's low oil or low oil pressure?
Brandon302 said:That doesn't sound as fun as the Ecoboost monster motor.
GottaBoss said:I've wondered since I got my car about the lack of an oil pressure gauge - either physical or through the gauge display. Are you guys saying that there is no 'low oil' indicator? Is there a 'low oil pressure' indicator? I sure as heck hope so. I can't imagine that any vehicle would not include any of these.
LOL, exaaaacctly.NewBossowner said:It has been my experience with factory oil light indicators, that they come on just to let you know that you need a new motor. Not to warn you that are a little low on oil and should put some in. if you see the little red light, get a tissue and have a good cry, cause it's over.
