What did you do to your GT350 or S550 Mustang today?
Discussion in 'TMO General Discussion Forum' started by cloud9, Nov 27, 2015.
  1. VoodooBoss
    VoodooBoss Rick Moderator
    19,492
    2,039
    Nov 30, 2010
    Please provide some feedback on the Drake's after you have some track days on them. I'm curious how they will hold up.
    DocWalt likes this.
  2. Black Boss
    Black Boss TMO Addict
    1,562
    927
    Sep 29, 2012
    Michigan
    Car prepped and Ready for Watkins Glen, Monday/Tuesday with Chin.
    Increased front camber from 2.1* to 2.7* using a combination of the Ford Service strut Bolts and MM camber plates. About 3mm of clearance from Hoos 315/30R19's to strut.
  3. DocWalt
    DocWalt TMO Advanced
    112
    96
    Aug 10, 2017
    Pennsylvania
    You don't have the struts slotted, correct? I was hoping to run that size tire all around but I don't have camber plates and I'm maxed out at -1.8 on the front with slotted struts and service bolts. :(
  4. Black Boss
    1,562
    927
    Sep 29, 2012
    Michigan
    No I don't have the struts slotted. I did grind the thick part of each of the service bolts on one side to allow more movement. I think you'll need camber plates to run Hoos 315's with moderate-high camber. The 315 PSC2's will likely fit -- their sidewall is more tapered.
    DocWalt likes this.
  5. bpracer
    bpracer Mark
    391
    251
    Mar 7, 2016
    DFW, TX
    Picked the car up and the check engine light came on went off within first five minutes. Came on again as I passed the dealer to go home... Sitting there now while they pull the code.
    It's not reassuring.
    This engine has less piston slap noise though.
  6. TMSBOSS
    TMSBOSS TMO Addict
    3,419
    689
    Aug 23, 2011
    Ouch. Hope it's a sensor, wiring glitch.
  7. bpracer
    bpracer Mark
    391
    251
    Mar 7, 2016
    DFW, TX
    They say it's from some tests the ran earlier.
  8. TMSBOSS
    TMSBOSS TMO Addict
    3,419
    689
    Aug 23, 2011
    Sounds like a software issues. Should be an easy fix.
    Hang in there.
  9. Black Boss
    1,562
    927
    Sep 29, 2012
    Michigan
    @bpracer Be sure to check that the dealer did a re-learn on the Crank position sensor. Any Trans/Clutch/Engine swap will generate codes and a CEL without this.
    TymeSlayer and VoodooBoss like this.
  10. bpracer
    bpracer Mark
    391
    251
    Mar 7, 2016
    DFW, TX
    Not sure what codes popped, but it will be going back to fix the splitter reinstallation. Looks like the center section is not right not sitting flush. I may just do it myself though.
    Can't even drive the car, the registration expired while they had the car and I'm going out of town again so can't take care of it anytime soon.
    I do have plans for the car. I bought a used trunk lid painted the right color, shadow black, with no spoiler holes for $80, local pickup! And I have a hood that I bought for $600 shipped! I'll have to get it painted, or at least parts of it as it's magnetic now.
  11. 06mach1
    06mach1 TMO Addict
    930
    85
    Jul 27, 2011
    Bliss, NY
    I finished up my rear seat delete, install my passenger side sub belt mount and Oreca belts.
    VoodooBoss, TymeSlayer and DocWalt like this.
  12. JeffV8
    JeffV8 TMO Race
    233
    164
    Jul 27, 2017
    Monaca Pa
    Does the submarine belt go under the mount then up and attached ??
  13. VoodooBoss
    19,492
    2,039
    Nov 30, 2010
    @06mach1 Mike, looking good. Which RSD kit did you use?
  14. 06mach1
    06mach1 TMO Addict
    930
    85
    Jul 27, 2011
    Bliss, NY
    Built my own RSD, just like I did with the Boss. This was a little easier though.
  15. 06mach1
    06mach1 TMO Addict
    930
    85
    Jul 27, 2011
    Bliss, NY
    The sub belt attaches to the mount then goes between the bottom of the seat back and the bottom cushion (in the split between the two). You actually sit on the sub belts.
  16. JeffV8
    JeffV8 TMO Race
    233
    164
    Jul 27, 2017
    Monaca Pa
    I know how they are routed. I figured out what I was looking at. I have your mount.
  17. JeffV8
    JeffV8 TMO Race
    233
    164
    Jul 27, 2017
    Monaca Pa
    2CF9B17A-D580-4CA1-BD00-F897704D49BC.jpeg EC9A26C0-C84E-4B78-BAAC-99BB7D794878.jpeg 7570D7D4-9220-48EA-A802-310164CCA518.jpeg What a difference this power pack 3 made. 5 hours to install in my driveway. My friend did the download and tune. I can’t wait til next Wednesday and take it to Track night. I hope to break the 2 minute time.
    Fastfordnut, spartan, RES_22 and 2 others like this.
  18. DocWalt
    112
    96
    Aug 10, 2017
    Pennsylvania
    What track are you going to?
  19. JeffV8
    JeffV8 TMO Race
    233
    164
    Jul 27, 2017
    Monaca Pa
    It was Beaverun now it’s called Pittsburgh International Race complex. The new owners have made the track so much better. First weekend in August the Trans Am series will be there.
    DocWalt and RES_22 like this.
  20. DocWalt
    112
    96
    Aug 10, 2017
    Pennsylvania
    Jealous! Have fun! I've only run the North loop there, back before they built the South loop. Still had a blast, lovely facility.
    JeffV8 likes this.
Share This Page
