If I buy 18" wheels that's the exact setup I'll go with. Let us know how they work for you.oldbossman said:OK, I received my PF01's from LSD Motorsports in California. They also mounted the Nitto NT05's before shipping. They gave me a good deal and would recommend them if you are looking for new wheels.
This is what I ordered:
front 18 X 9.5 35 mm offset in black and 275/40/18 Nitto NT05
rear 18 X 10.5 38 mm offset and 295/35/18 NT05
I have changed brake pads to (perf. friction 01 compound) in front and replaced the brake fluid with Motul. My track event is next weekend and my question to those that have run Nitto NT05 (or NT01) is what cold tire pressures did you run - front and rear?
oldbossman said:My track event is next weekend and my question to those that have run Nitto NT05 (or NT01) is what cold tire pressures did you run - front and rear?
Did you end up at 40 hot after you started 33 front and 31 rear cold? You should generally be shooting for about 40 hot on street tires.drano38 said:oldbossman said:My track event is next weekend and my question to those that have run Nitto NT05 (or NT01) is what cold tire pressures did you run - front and rear?
Like Scott just said, low pressure works well for him.
But last Friday, I opened the season in Iowa, and ended up with 40 psi hot. It was cold (45 in the morning, 65 in the afternoon), so that may have been part of it. But I was getting fairly even temps across the tire face.
So pic a number, check tire temps on outer/middle/inner tread as soon as you park, and adjust from there for even temp and/or even wear pattern.
Scott and I have proven that Your Mileage May Vary.
Have fun.
cloud9 said:Did you end up at 40 hot after you started 33 front and 31 rear cold? You should generally be shooting for about 40 hot on street tires.drano38 said:oldbossman said:My track event is next weekend and my question to those that have run Nitto NT05 (or NT01) is what cold tire pressures did you run - front and rear?
Have fun.
drano38 said:Gary,
They're now 35 front/33 rear in my 52 degree garage.
At the track, I stopped measuring cold tire pressure thru the day--just kept watching hot off the track. But I drove home w/o lowering the pressures (doh!).
drano38 said:Looks good Dean.
Do you have MM camber plates?
How much camber did you set?
