Wheel/tire packages for track
BossJockey said:
Dean#4AI said:
rcode1965 said:
Those Forgestar's look great Dean. Been thinking of getting a set also, or at least it's one of my favorite's so far. Can you tell me what size of wheel and tire size you went with? Thanks.
I'm running a square setup with 18x10 wheels and 275/40 Nitto NT01 tires. The tire diameter is the same as the stock 19s.
Did the fronts fit without a spacer?
Yes, no spacers.
Dig-It
Kevin
238
8
VA
cloud9 said:
It's most likely a P0300, P0305 or P0306. It's pretty common from track use. The PCM perceives misfires, but they're "phantom". The cure is to have your dealer perform a cranshaft sensor relearn process. The crankshaft position sensor is getting fooled into reading misfires. Scott said Ford told him it's from hitting the rev limiter while I had another Ford person tell me it was from vibrations transmitted through the driveline from track curbing. Either way the crank sensor relearn TSB is the cure.
I haven't got those codes (yet). My Boss will pop 0446 evap/emmissions every so often if I don't allow for a short cool down after a hot run.
Misfire are the most common codes but I have also had P0200, P0222, P0131 in addition to the P030X codes.
OK, I borrowed a set of R6s (275/35/18) for today's time trials, immediately dropped 1.5 seconds off my best time on NT01s. These tires are no joke! Looks like my buddy can get them for $1200/set, so I might just start buying em...
PeteInCT
2,848
14
They are stickier but will also cost u more in the long run if thats a concern. For straight HPDE's i"m goodv with the NT-01's brother, the NT-555R-II.
PeteInCT
2,848
14
It ate my Corsa's fast, I can't imagine hiow fast an R6 would get eaten up. My guess is 3 track days tops.
How many track days did you get out of your Corsa's?
For those using street tires I finally ran my Toyo Proxes 1's this weekend and Proxes 1's < Pirelli P Zero. Next up probably either Yokohama AD08 or Michelin PSS if I stay with the 19's.
PeteInCT
2,848
14
I got less just over 4 track days on my left front tire. I may have gotten a little more if I was running less pressure fron the start. The other 3 are still on the car and I guess I have 2 more hard days on them. A lot of my days were at Lime Rock Park, it's not the fastest course but at the same time you are always turning, and most of the turns are at higher speeds (there are no hairpins that force you to slow down too much).
The AD08's may give you a bit more grip than the PSS's but the PSS's will last a lot longer and will kick butt in wet conditions. To me that's the best overall non r-comp tire out there.
So maybe six days then. That's more than I thought.
I'm more interested in grip than running in the wet. Remember it never rains in CA....except for when it rains. :D
Pete, that is more then most others were reporting. I am getting two - three days (2.5-3.5 hours) on a set of the Conti/Hoosier take-offs, that's a deal.
PeteInCT
2,848
14
I expect that from R6's - these are the Pirelli so you get a little more. The bad part about the Pirelli's is you can't grind them to the bone, the rubber peels away (in chunks) well before you really get to the cord. Not what I expected from a $600+ tire. Nitto's here I come !!
A Boss owner local to me has Corsa's and had them shaved 4mm. They seem to be holding up ok so far but he's already stated he won't buy them again.
PeteInCT
2,848
14
I'd prefer a little closer to back seat actually. And have her shed about 400 lbs or so.... Oh wait, that a GT3. And we can run with that. Nevermind.... ;D
