- 289
- 0
Would adding reflective tape/foil or an aluminum plate just reflect the heat on to the main bodywork of the car and heat the body panels instead?
There's not enough sustained heat running at WOT from street driving to melt them. You'd be in jail before you got them hot enough on the street.98RedGT said:so we are saying that this is an issue only when running on track? is anybody seeing this issue with just street driving?
Can someone please help me out with a copy of the maintenance supplement?PeteInCT said:Nope - check the maintenance supplement. Ford states if you track the car to remove these puppies. They saw it coming.
Even with side plates removed and TracKey enabled?cloud9 said:There's not enough sustained heat running at WOT from street driving to melt them. You'd be in jail before you got them hot enough on the street.98RedGT said:so we are saying that this is an issue only when running on track? is anybody seeing this issue with just street driving?
I had my side plates removed from day one. I didn't melt these until I put it on the track on a very hot day. TracKey shouldn't affect it one way or the other since it appears to behave the same at WOT as black key.Vince said:Even with side plates removed and TracKey enabled?cloud9 said:There's not enough sustained heat running at WOT from street driving to melt them. You'd be in jail before you got them hot enough on the street.98RedGT said:so we are saying that this is an issue only when running on track? is anybody seeing this issue with just street driving?
cloud9 said:Looks like it's time to find a good street tire for the street and Hoosiers for the track
cloud9 said:Has anyone figured out a good option for slicks?
Car is just like it came from Ford, Extended runs?......Nope. Saskatchewan?.......nope Virginia...............Just a few 1/4 mile runs..........killed one new SS Camaro. LOLPeteInCT said:I'd assume that:
- You have the restrictor plates in
- You havn't pushed the car hard for many extended run(s)
- You live in Northern Saskatchewan ;D
