Im about to do the same also. I was also looking at going to royal pure for my next oil changeufnavy06 said:So far, I've just gone OEM with the Motorcraft. However, I'm about to switch to Amsoil as I've heard nothing but good things for years now. I've been meaning to do it for quite some time, but that time is now.
PeteInCT said:Guys,
From everything I read and hear AMSOIL is an excellent oil. However, as far as I know AMSOIL still does not make a 5W-50 weight oil. There has been a lot of forum discussion on this over the last year. Long story short, I personally would not use anything other than a good quality fully synthetic 5W-50 weight oil (Full disclosure: Some forum members have used different weight oil and so far no one has made any connections to problems AFAIK). Ford has stressed this point emphatically, and I really don't think it is because they are just trying to sell Motorcraft oil (they do not state that you must use their brand). Our engine variable valve timing system uses a solenoid managed valve that controls engine timing, hence the quality and weight of the oil we use play a key factor in long engine life. The fact that we redline at 7500 at almost full engine power also bears weight on this.
Long story short, and especially if you do not track your car, I'd stick with Motorcraft oil (or similar, I personally use Castrol Syntec Edge) and just change the oil and filter frequently, maybe every 3000 miles. Once the oil starts to get dirty it's your enemy and no oil formulation is going to counteract that.
FYI - Royal Purple uses graphite in their formula AFAIK, and some say that's bad for the long term whereas other drivers swear by it. Where the truth lies IDK, but I'm not willing to try it and find out the hard way unless I can see some empirical evidence that it does more harm than good.
-Pete
As Far As I Know.Smilieboy said:what does AFAIK mean?
ace72ace said:Ford only has to recommend an oil that is good enough to get through the warranty period,
four-walling said:Huh???
BOSS2664 said:DKL,
I had this debate with myself when I was up for my first oil change on my '12 BOSS. I chose Mobil 1 5w-50 and I got it from Napa, and at a good price too. I use a Motorcraft oil filter (stock specified part). I change my own oil and really thought to myself that I've used this oil (Mobil 1 brand) for a long time and have used it in everything from turbo 4 bangers to old chrysler slant 6 engines. It's never let me down. I Probably owe it to the fact that I perform routine oil changes. Thats probably the most important thing, a routine/faithful oil change. I don't think a Ford service department would deny any warranty work for not using the Motorcraft oil, as long as you have receipts/records of good major brand oil and oil filter used in your Boss' oil changes.
I had actually thought that Mobil 1 would be the one I was going to use. I have pretty much used Penzoil in my truck and my wife's car, mostly because the quick lube shops all have it. I have always changed oil in all of my vehicles at 3000 miles, except for the 69 Chevelle, it was always sooner because of the way I drove it. I have always heard good things about Mobile 1 and a car like this deserves only the best. That is why I wanted to get opinions from guys I figured had the answers...Thank you sir...
