Whiteline Heavy Duty Adjustable Rear Sway Bar
Packaging is very nice
Some comparision
Install time!
I test fit the axle brackets then marked the centerline of the axle and the bracket for alignment
Final install
The install, kind of sucked doing it in the driveway the way I did it. There were just a lot of things you have to hold in place, initially to get the nuts started. I will also say the instructions you get are not really that great, when you need to figure out what washer/spacer goes where, thankfully Vorshlag has full color pictures on their site, and had a better set of instructions on there too, that did not even come with the kit(I purchased from AM). All in all not too bad as far as install.
As far as function goes....WOW...it was a noticeable difference, I made the mistake of taking it out on a test drive on the hardest setting......oops. On street tires, in the corners, the rear was so stiff, the car would just break loose with a slight stab of the throttle. I put it back on medium at is was pretty damn nice.
As far as material, and quality...forget about it...this thing is the $hit!
Cant wait for the track. Should be doing Watts link this weekend!!
Some comparision
Install time!
Final install
