- 675
- 253
. . . that changing out the UCA by yourself is a massive, huge, gigantic, colossal, freaking ridiculous pain in the neck???
That is all. Go about your business.
John
John
You obviously don't spend enough time reading this forum.Champale said:. . . that changing out the UCA by yourself is a massive, huge, gigantic, colossal, freaking ridiculous pain in the neck???
John
Champale said:I've done all manner of minor projects on this car - LCAs, relo brackets, panhard, GT500 mufflers, MGW, etc - with few problems (not to mention countless other projects on other cars, bikes, and trucks) . The UCA absolutely takes the cake.
i disagree if you do both bracket and arm at the same takes all of an hour. Long tubes takes min of 4-8 hours depending on brand.2012Boss302 said:To try and put things in perspective, the UCA and bracket are a hell of a lot easier than long tubes....
Champale said:Wow, if you guys can remove the factory UCA and bracket, install a new Whiteline UCA and bracket, and set the pinion angle in an hour - on jackstands and using hand tools in your driveway - I need to come watch how you did it! The fact that the bolt at the top of the differential seemed to be set by the factory at approximately 74,000 ft lbs didn't help!
steveespo said:Torque spec on that bolt is 350 ft/lbs. need to find a 3/4" drive torque wrench or set an Ingersol Rand impact gun to kill. Only part on my chassis I haven't touched yet.
my steeda bracket and UCA called for much lower around the 120's I do believe. came with new bolts. I used a breaker bar with the handle to my jack on the end to break the bracket bolt loose on the inside of the car. I did the entire install with hand tools. like I said not fussing with reusing the stock mounting bracket makes it much easier. the stock bracket is laughable in comparison to my steeda bracket.steveespo said:Maybe BMR only needs 129 but the Ford Service manual calls for 350!!!
http://iihs.net/fsm/?dir=731&viewfile=SPECIFICATIONS.pdf
What diameter is this bolt?steveespo said:Maybe BMR only needs 129 but the Ford Service manual calls for 350!!!
