Wilwood Big Brakes, Corsa Exhaust, Whiteline Watts link and more
All pictures are at the following link: https://www.dropbox.com/sh/zen8djft8esg4a3/AACV6eh8wCNBRiuf0vCfF-zQa?dl=0
As always, prices are "or best offer".
Wilwood Aerolite 6R/4R Race Brakes (6 piston front, 4 piston rear)
These brake parts were used for 1 season only
Front (part #140-13882-N):
Freshly rebuilt 6 piston calipers with 1 race after rebuild at the end of last season
2 brand new rotor rings freshly cryo treated by Frozen Rotors
4 more used track rotor rings-do have heat cracks in varying amounts-"use at your own risk"
4 rotor ring mounting hats with floating bobbins
1 set of used H compound pads-8mm remaining
All brackets and braided lines that came with the kit
$2000 obo
http://www.wilwood.com/BrakeKits/Br...=2012&make=Ford&model=Mustang&option=Boss+302
Rear (part #140-10950):
Freshly rebuilt 4 piston calipers with 1 race after rebuild at the end of last season
4 used track rotor rings, better condition than used fronts-no cracks, but do have heat marks
4 used rotor ring mounting hats with hardware and 2 packs of extra hardware
2 sets of used H compound pads-8mm on one, 9mm on another
Come with parking brake cable assembly to make shoe style parking brake functional
part #330-12335
*these calipers do have some custom machine work done to them, but does not affect function. PM for more details
$1200 obo
http://www.wilwood.com/Hardware/HardwareProd.aspx?itemno=330-12335
GT500 rear brakes with Pagid pads and Blow Fish brackets
Rear GT500 calipers with 60% used brake pads.
Factory GT500 brackets, as well as brand new Blow Fish Racing aluminum brackets ($189)
Brand new in box Pagid RS29 brake pads #E8113 R29 01 ($199)
6 Rotors all used, see pictures for condition
$400 obo
Corsa Axle back exhaust
https://www.americanmuscle.com/corsa-xtreme-axleback-1114gt.html?utm_content=Exhaust - Axleback|Corsa&utm_campaign=AMM 2005-2014 No Years&utm_source=google-pla&utm_medium=shopping&T5_Var3=blue&T5_Var4=100512
$350/obo shipped
OEM s197 8.8 axle housing
Comes with stock axle shafts
$250
Feel free to email me directly at [email protected] or call/text 612-220-5929
I was under the impressiont that the rears on stick axle cars cause knock backon the pads. Am I wrong on this?
You are not wrong at all. In fact, the factory rear axle shaft have so much flex, that we had to machine a small area in the caliper to clear the rotor when the axles flexed under hard cornering. A few of the reputable axle manufacturers make replace axles that are significantly stronger and have much less flex to them, which does help with this issue greatly. If we had not gone with the Cortex cambered rear on this car, we were going to go that route in order to decrease knock back.
