Winter Mods 2014/2015
Ok the track and car show season is winding down and it's time to start thinking about mods for next season. What do you have planned for this winter? New wheels and tires, engine, suspension, stereo upgrade?
Tucson 302
2013 Black LS #439
Did the full interior gut this weekend and installing the full halo seats plus the six point belts from Pete. Full cage and fire suppression are next hoping to have those in by this time next year
buland
One of the rare Boss LS in Switzerland
GT/CS fog lights on the ghig and reduce the rattle from the blowfish shifter fix.
Ls rear wing and 2013 shelby rear exhaust
Fix the belt helper on passenger side
Oil and filter change with frpp oilfilter and mobile1 5w50
Stereo upgrade on the sby ls
Gesendet von meinem iPhone mit Tapatalk
302 Hi Pro
2,009
438
Southeast
A "Mustang Clubs Racing Team" graphics package with round logo and flag for the rear quarter panels.
2HP
302 Hi Pro
2,009
438
Southeast
They would look good together, but the MCRT has history and was used on the 1969 Boss program cars. I have a 12, so it should look nice with the C stripe.
Do you sell BMO graphics?
2HP
dmichaels
Papa Smurf
547
30
CT
Roll cage and corresponding rear seat delete
6-pt harnesses
Fix the rear brake issue (believe bent axle)
New helmet
HANS device
Possible other projects
Make CF or fiberglass hood
If ^ goes well, CF or fiberglass rear wing
If ^ goes well, CF or fiberglass trunk
8,571
2,439
Roadmap:
December:
Aluminator NA shortblock 11:1
Moroso Road Race oil pan
Fresh FRPP BOSS valve springs
Watson Racing Motor Mounts
MMR Coolant Bridge
MMR billet crank sprocket
Fresh OEM timing chains
Remove AC compressor
EVAP System delete
April:
Dynotech Aluminum DS
302S front LCAs
Prothane front LCA bushings
Lightweight Battery in OEM location
MCS 2-Way non-remote suspension from Vorshlag or JRis from Cortex/Maximum
Remove stock door beams
Re-Corner Balance & Align
1,022
97
Texas
ArizonaBOSS said:
Roadmap:
December:
MMR Coolant Bridge
EVAP System delete
February/March:
302S front LCAs
Just curious why you don't relocate the battery to the trunk? With your interior out that shouldn't be difficult.
8,571
2,439
We did that (relocation) in our LeMons car and we have added about 30 lbs overall weight of heavy-gauge wire to accomplish that.
Going to lightweight battery in the stock location drops 30 lbs overall, and saves me the purchase of the wire (about $75), and a battery relocation kit ($200-600 depending on source).
I like this strategy and you may recall the first time we met we were told it wasn't worth the effort to relocate it to the trunk. ;)
1,281
Tulsa, OK
I've considered relocating the battery too but for the price, hassle, and extra weight I think I'll just add a lightweight battery in the stock location once mine goes bad :p
Have a collection of upgrades in the Basement:
Kooks Long Tube headers (1 7/8") plus Off Road H Pipe
Solid Engine Mounts
Stainless Clutch line
Plan on ordering the Cortex Watts link - will talk to them and Rehagen re weld v's bolt in
Will likely upgrade the Engine Harness -- threw a couple of camshaft position sensor codes during idle at my last track day, but no limp mode yet or codes during hot laps.
