Welcome to Track Mustangs Online
Join the BEST track enthusiast Mustang community on the web!
Register Log in
"Wrench" warning light
Akula23
TMO Beginner
Messages
9
Reaction score
Location
Raleigh
Hi all,
Maybe there is a thread for this already, but I haven't found it. My 2017 GT350 gives me a "wrench" light with the message "See manual". I can't find any wrench symbols in the manual. It clears after the car is shutdown and leaves no code. When the light comes on (after 30-60 minutes of driving), the cruise control stops working. Otherwise, all seems fine.
My engine is stock with the exception of a JLT CAI and JLT tune. The car has 5500 miles with several track days and auto-crosses.
Anyone know what is going on with this one?
Thanks!
Messages
273
Reaction score
241
Location
Gilbert, Arizona
I failed to properly heat up the motor at a track day (didn't have oil temp to 200F), the car limited rpm's to 7500, showed the wrench then cleared when the car was turned off. Next session it was like normal. I drive a '17 gt350
Akula23
TMO Beginner
Messages
9
Reaction score
Location
Raleigh
That sounds promising. I’ll call the dealer tomorrow. Thanks!
JAJ
TMO Addict
Messages
688
Reaction score
647
Location
In the V6L
over an hour and a half to replace a nut?????....they must have one doing the job................
It's the nut on the end of the transmission tailshaft. You have to remove the exhaust and drop the driveshaft.
JAJ
TMO Addict
Messages
688
Reaction score
647
Location
In the V6L
Thanx for clearing that up.....It would probably take me 3 hrs.......................Me and Murphy
It's just further evidence that the vibration from a Voodoo will eventually return anything connected to it back into a pile of loose parts.
VUDU V8 Steve
TMO Intermediate
Messages
13
Reaction score
8
Location
chico,ca
The tune likely optimizes whp and torque and ignores a bunch of other functions. Plug in your tune hardware, return to stock, and see if it goes away.
If it does, JLT propeller heads should interrogate your car ( after you plug it back in and restore tune, reproduce driving conditions, and throw another wrench light.)
and fix it.
MY tune ( Paramount Speed/ Palm beach Dyno) added 20 whp/ 20 ft lbs torque, but car is jumpy and stutters when cold, and it wouldn't smog because tune software erases the "black box" in favor of maxing out the ponies for tracking. I drive my car stock, and return programming to tune when tracking...
Akula23
TMO Beginner
Messages
9
Reaction score
Location
Raleigh
Turns out my Autoblip was interfering with the clutch position sensor. After disconnecting the Autoblip, the problem went away.
Messages
3,541
Reaction score
856
Location
NY Metro
Hi all,
Thanks!
Wrench light is specifically related to throttle body calibration. If the commanded position and actual position don't agree within .5 degree wrench light will illuminate and put the car in limp mode. I am not aware of the light coming on without reducing power.
Black Boss
TMO Addict
Messages
1,842
Reaction score
1,594
Location
Michigan
Wrench light can also be caused by issues with pedal switches or Magneride. It's sometimes accompanied with either a (delayed) Hill Start Assist or Cruise Control not available message. I had a Wrench light and Hill Start assist caused by a Stop light switch failure (turns out the switch has two switches/circuits, one used for brake lights, the other for Hill Start/Cruise, only the latter had failed). Magneride failure will set limp mode and eliminate ability to change drive modes.
Most Wrench light conditions will reset on key-off. Some require battery power to be disconnected.
Messages
3,541
Reaction score
856
Location
NY Metro
Thanks for additional insight Nick. I have been reading through the 2018 Diagnostics manual and the interaction with all of these systems has multiplied 4 fold over the S197. There are 4 High Speed Can buses in an S550, 1 in the S197.
Black Boss
TMO Addict
Messages
1,842
Reaction score
1,594
Location
Michigan
Yes, 4 CAN busses (3 High speed, 1 Medium speed) and a gateway module to translate info between busses and to the OBD port.
Not many aftermarket diagnostic tools will correctly read all data other than CAN bus 1, which is mainly PCM info. Even some versions of ProCal will not read ABS, Power Steering and other modules on multi bus systems.
I’ve found FORScan Lite to be the most comprehensive diagnostic and logging tool.
