Bang for buck camber adjustment
looking to get -2 to -3 degrees of camber in the front
car has stock springs with koni adjustable shocks, wheels are a 18x9.5 ET 45 with a 20mm spacer hoping to run a 275 or 285 tire
wondering which camber plates and or camber bolts are worth buying and which ones are generally considered junk
I had Vorshlags on my '16, with cutting the strut towers was able to get -4. But that was a heavily modded car that was pretty much track only. With the Mach 1 I put on BMR and with no massaging I got -2.2 which I think is fine for a dual purpose car that will see more street than track time.
It's funny I did it the other way around from you: I had BMR on my 2019, and I bought Vorshlag for my 2024. I have yet to install them. For having tried both, do you reckon I should get more camber with the Vorshlag, without cutting the strut tower, or is 2.2 pretty much the max you can get irrespective of brand?
I think you can get more than 2.2 with the Vorshlag without cutting. I think I got a little over 3 when I first put them in. Just had to go for more though. It was a very worthwhile thing, that car was on rails.
Think about biting the bullet and doing the camber plates once with the Vorshlags. It stings the pocket book in the beginning but could save you in the long run buy not having to purchase and maybe pay for labor on a second set when you realize you want/need more camber. The second set will probably end up being Vorshlags... I'm at 3 without cutting the towers on an S197. If you can't afford now you could take the offer on the camber bolts and have a good alignment shop max you out and have fun. It might be harder on the tires but gives you time to save.
View attachment 94665 Nothing says , Bang for your buck , like simply drilling the towers and getting -3 degrees that will never go out of adjustment. It's old school but it works!
I had actually considered doing this! My only concern was not being able to adjust it later if I decided to change the setup but I guess I could just buy camber plates at that point
Buy once cry once. That is a good way to look at it as well. Does Vorshlag still make the camber plates for the s197 new or would I have to find them used
Yikes! I'm glad I got mine in 2021. They went up just like everything else. You definitely do get what you pay for though.
Add me to the Vorschlag list. I've got them installed on my '18 and just need to get them installed on my '08. I notched the towers on my '18, but don't get anywhere close to them at the 2.7 degrees I'm set at. When I initially took it in to get aligned I was well over 3 degrees without getting into the notch. The price has definitely gone up the last couple of years. I'm glad I got them when I did.
