Welcome to the Ford Mustang forum built for owners of the Mustang GT350, BOSS 302, GT500, and all other S550, S197, SN95, Fox Body and older Mustangs set up for open track days, road racing, and/or autocross. Join our forum, interact with others, share your build, and help us strengthen this community!
Is the Ranger clutch reservoir you refer to a OE Ford Ranger piece? I only recently discovered the GM clutch reservoir is on back order indefinitely. (see full post)
Wow, that kit really exploded in price for some reason. Maybe because it was a short-run part for the few years of the S550 GT500? I still have that kit in my stash from when I ordered it back in Fall of 2020... $699.95 on the receipt from Summit... (see full post)
The limited slip in my 2011 GT is gone. Any lateral loading creates a one wheel peel. On the lift, spinning one wheel creates no movement in the other. Other trac-lok cars, both wheels spin the same direction. This car behaves like its full...
Got my OBDII cable today and downloaded Forscan. I played a little on my 2017 Fusion. I was able to turn of the annoying auto stop/start and disable the manual switch so it doesn't display messages on the dash if you accidentally hit it. There... (see full post)
Just a quick photo dump, car is still disassembled getting the rear brakes, rear shocks, and rear brake lines wrapped up.
I took it on a quick run to get gas for the first time since installing the engine, successfully made it back and has fresh... (see full post)
Thanks, yeah I have a start at a similar sheet.I already have some of those parts on my busted Gen2 (cylinder heads, valve cover, ported throttle body), but a few of these were not on my radar. (see full post)
Picked this up from a very nice TMO member. Now need to find a seat delete panel, install it all and then figure out our track schedule. (see full post)
You and I are both in the market lol. I saw your post on M6G a couple days ago. This is what I have planned after talking to a few nice folks on here and Shaun at AED. (see full post)
The nankangs are underrated for a 200tw. They are very good and come in big car sizes. Only thing that outruns them are yokohama AO52. Good wear, fast to the cord, and can hook up a gt500 in 2nd gear.For SCCA which is 200tw focused it is... (see full post)
Overlaying the stripes with a blue stripe and white pin stripe to match the numbers on the door I think could work. I think you need a blue or a grey main stripe to work with the other colors. (see full post)
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
