Brake pressure available via CAN?
Is there any brake pressure data available over CAN? I am trying to setup my display dash for data and wasn't able to get brake pressure.
I am not too knowledgeable in the electrical department for the cars but I am able to get brake pressure using my Race Capture connected via OBD. I think it takes some reverse engineering because I’ve seen it mentioned in the FB group when someone was trying to figure it out using AIM DL
I'm able to get brake pressure using the Boss302R config in AIM Racestudio.
I also have the Ford Racing ABS module installed. Car is a 2012 Boss 302
captdistraction
GrumpyRacer
what system are you using? If you can manually map channels, try (this is from a 2017)
Channel - CAN ID - Offset (Len) - Formula
Brake Pressure - 125 - 0(2) - x 0.025 / 1 + 0
Latest lap times
