Hello everyone here,
I own a 2013 Boss 302 I recently got the red track key activated it works and functions as it should. Before I got it activated all of the Gauge Details worked perfectly it was showing everything Air/Fuel Ratio, Cyl Head, Inlet Air, Oil Press, Oil Temp, and Voltage. After getting the track key activated and drove the car home about a month went by and I decided to take a look at the Gauge Details just to check all my numbers and i noticed that they are all blank, the only ones that are showing are Voltage and Oil Press says Normal. I tried changing the battery, and also did a system reset on the dash to no avail sadly. Has anyone experienced this issue before, or know what might be causing this with a fix? I will add two photos as reference. Thanks for everyones time.
