S197 2005 GT Build Thread Profile - S197 Mustangs
How do you find the CSM spec tire compared to other options?
I haven't run the spec tire yet. Since I'm just starting out, I decided to go with Falken RT-615's since they are cheaper and I figured I would be burning though them while learning.
If you haven't purchased yet you might go with the 660+ instead.......easier tire to drive on for someone new as they telegraph much better and will be faster. Sure, they will wear faster but some drivers find the 615s to be rather uncommunicative.
I already have the 615+. I considered the 660+, but they were more expensive. Another benefit to the 660+ that was pointed out to me by a friend, is that they can be flipped on the wheel to get a little more life out of them.
Once I wear out the 615+, I'll switch to the spec Goodyears.
