R7 tire problem
5,659
4,939
A recent batch of R7's for a friend with a 800hp r7 and a Porsche Cayman GT4 had a strange tire failure on both cars.
this was on the M3...
And these on the GT4....
This happend on the 2nd track day and both cars are about 1600kg. He says they were at 30psi hot. Any ideas?? Have not seen this before.
I'm going to throw out an educated guess and say its a compound/process problem. Look closely into the tears and you can see strands between the edges of the tear.
"Plastic deformation is the permanent, non-reversible change in shape or size of a solid material that occurs when it is subjected to stresses exceeding its yield strength. Unlike elastic deformation, which is temporary, plastic deformation involves atoms slipping past each other or permanent shifts in the crystal structure, meaning the material does not return to its original form once the load is removed."
I'm sure a materials scientist would be able to compare 2 samples and see what was different. Hopefully its just a bad batch and not a new compound fault.
Yup that more or less what I thought as well. They look like shear tears. These were R7's from a batch a few months ago.
No idea what happened (but that one tire looks to be dated 2023?) but you shouldn't have to worry about an R7 batch problem since the R8 is a thing now...er....trackattackpro or whatever they call it.
All the R7 tires at Tire Rack are marked for clearance. Hoosier is no longer making the R7.
Are these the tires you normally run? It looks like both are a combination of not enough negative camber and too much understeer. The wear has a regularity to the pattern. It's not just pick-up. It looks like in both scenarios you have a driver who cranks in a ton of steering while still hard on the brakes.
I have never run these tires, but 30 psi would be on the high side for me.
Sadly this is exactly how you drive this new M3's fast on track since they are AWD the understeer in corners is a natural characteristic.
This is for another fellows car.. He is mostly in time trials and have not seen him race. For my boss, I found the sweet spot for tire wear vs performance was 32 front/30 rear. But AWD and loads of torque is going to be a different animal.
