This is an interesting topic as I too experienced an on-track, straight line, Hoosier R7 tire failure which led to the ultimate destruction of my Mustang. The tire was a R7, P315/30/ZR18, date code 1722, incident date 7/2025 with 9 total heat cycles on the failure tire since new. Hot pressure was set at 32 psi. Note Hoosier Tire states in their on-line “A7/R7 Tire Care and Safety Guidelines” for a vehicle weight over 3000 lbs, recommended Hot Pressure 40-42 psi. The failed tire tread totally delaminated from the tire carcass. The carcass which remained mounted on the rim showed two hole locations breaching the carcass spaced approximately 135 degrees arc segment from each other. Both show rubber shards emanating around the holes in the outward direction as if blowing outward from the pressure chamber inside the tire.
Over the years, I have recorded data on 24 identical size, P315 Hoosier R7 tires run on my car with different mold dates. Average life of this 24 tire set was 37 track heat cycles. This tire failure at 9 heat cycles just does not family with the other collected tire information.
