This is the Build Thread for FR500S #32. Reply below.
I simply did a Google search on "what fuel injectors were used for the ford fr500s" and the AI answer is "The Ford FR500S track-day car came equipped from the factory with 47 lb/hr fuel injectors. These high-impedance, multi-hole injectors were part of the Ford Racing catalog."I haven’t seen that can you point me?
Amen, brother, the Phoenix cars are the gold standard for S197sYou are in PA., why not take it over to Phoenix Performance, LLC in Phoenixville, PA., as they have a ton of experience with S197s having fielded a boat load of " National Champion " Mustangs in SCCA!!
phoenixperformancellc.com
yea i have the same goals as u as in not going the boosted or stroked route just wanna do a max effort n/a build for my 06. thank you for the response, think im going to copy your engine build to a t. for the springs did you go 26113-24 or the stiffer 26125-24?@mostloved I used Comp Cams 127500. Per the web site the biggest cam without porting the heads. Per multiple tuner videos online the combination should yield about 350 which is 75 more than stock. I will post my dyno results when it is done mid July. This cam does require upgraded valve springs but it opens up the rev range to 6900.
Porting the heads and using the 127600 cam should be about 30hp more. Doing that would have added another $7000 to the job. That didn’t seem to be worth the juice.
