Just finished install of Diff Breather and cooler:
Remove Diff cover and Drill/Re Tap for Temp sensor:
Remove Breather and 1/2" plugs, replace with hose fiitings:
Use a bead of Silicon gasket and re-install Diff Cover:
Mount Vent to inside Wheel Arch and Cooler (with Fan) to Floor Pan:
Mount Pump in Spare wheel well:
Hoses:
Lower fitting goes to cooler, upper fitting to pump outlet, to keep pump fluid temps cooler.
Wiring:
I'm using an Aerometer gauge to trigger pump and cooler fan at 230 F.
Mounted relay and manual toggle switch (to prime/drain diff fluid when I change fluid) in rear wheel well (attached to rear mounted battery box).
Ran 2 wires to Smart junction box for relay trigger (3 amp add a fuse) and power (15 amp add a fuse).
![IMG_0846_zps42c4862e.JPG IMG_0846_zps42c4862e.JPG](https://trackmustangsonline.com/data/attachments/2/2197-1e95dd30995b55d21efb2a75b9f8dcd2.jpg)
![IMG_0845Medium_zps5eed5076.JPG IMG_0845Medium_zps5eed5076.JPG](https://trackmustangsonline.com/data/attachments/2/2198-5e749c78906ac71b8c1fe85b51677a52.jpg)
![IMG_0851Medium_zps8a900b01.JPG IMG_0851Medium_zps8a900b01.JPG](https://trackmustangsonline.com/data/attachments/2/2201-3e93069ad5b21c9ca963917a37bc811d.jpg)
![IMG_0850Medium_zpsca06a0ed.JPG IMG_0850Medium_zpsca06a0ed.JPG](https://trackmustangsonline.com/data/attachments/2/2200-54f09e3f2978b14115bb9f36c01aedb3.jpg)
![IMG_0848Medium_zps30bc3abe.JPG IMG_0848Medium_zps30bc3abe.JPG](https://trackmustangsonline.com/data/attachments/2/2199-1a963eec58f32358f5bf5bc78a9f6ad0.jpg)
Hoses:
Wiring:
