Picking control arms within the club spec rules
12
20
PA
My car is on the original control arms front and rear. After pittrace I noticed my RF control arm bushing leaking, which surprised me as I didn’t realize they are hydraulic.
For the front:
are the ford racing gt500 arms worth doing over the stock ones?
Rear:
I read Billy Johnson’s thread on motoiq. I know my UCA is in sad shape, I’m assuming a ford replacement would be better than a Dorman or parts store. Is the steeda bushing in the rules worth doing for the axle side, or should I get an oem replacement?
Also, are the FP gt500 rears worth doing?
6,447
8,370
For the front:
Rear:
In PWC we ran the non adjustable Ford Performance lower trailing arms, the Gt500 upper link is the preferred one, but a standard Gt one will work fine.
12
20
PA
What’s the difference with the gt500 upper? Just a different bushing? I couldn’t really find anything when I was searching. I ran across one of your posts about it. Do you think I should just press another stock axle side bushing in or use the steeda once since it’s allowed?
6,447
8,370
I think originally from the factory it was a different durometer, but they are hard to come by. I just use the stock Gt one in my track car, leave the bushings stock, but you can use urethane in the lower links, FR used urethane.
