SN95 RinerAutomotive's CAM-T Mustang Build Thread Profile - SN95 Mustangs
282
301
Virginia
Talking about the PS pump reminded me - if you ever have problems with cavitation in the PS pump, try the Redline PS fluid. Back when I was autocrossing the Neon, they had a tendency to cavitate on sustained hard inputs - end of a long slalom and suddenly you lose a bunch of power assist. The Redline power steering fluid solved that.
It's odd, I hear the sound during acceleration like from the start or from slow sweepers. but it eventually goes away and I don't feel any change in the steering. The end goal for me is electric power steering, so I'm not putting anything into the stock system. This has forced my hand to dive into that quicker.
282
301
Virginia
I've been slacking on keeping this updated, things have been busy.
The Ponies in the Smokies autocross was an awesome time. I managed to finish in first for the Ponies in the Smokies autocross and then competed in the King of the Smokies shootout with those 11 cars. We only got 3 runs and the course was reversed from the course ran during the normal autocross. I was the most experienced autocrosser and my car is setup for it, but never count out a GT500 or Mach 1. This course also was on a slope so there was a lot of downhill, uphill, and off camber corners. After 1 run I had a good lead. My second run was ~1 second faster but I picked up a cone right at the finish and someone went slightly quicker than me so I got knocked down to 2nd.
Last run I knew there was a lot more if I could get one particular corner right. There was a downhill off camber corner that I overcooked on each of my previous runs. Everything was feeling great as I came through the finish...another 1 second faster and clean! I won the King of the Smokies autocross by 0.9 sec. Doing what I had come out to do. I know the rest of the events are not going to go my way (drag race, dyno, car show).
Videos for all of my days at Ponies in the Smokies are available on this Playlist:
Playlist - Ponies in the Smokies 2024
282
301
Virginia
Awesome video! Makes me want to do this next year! What do you use for a camera to get the speed and coarse layout?
You're in luck I have a video on that 😁
But, I've done it two ways in the past:
1. I used to use Track Addict on a tablet to get GPS and OBD2. Then GoPro to record video on car. On PC use RaceRender to import Track Addict file and Video. Sync data and video and overlay is done
2. Use a GoPro Hero 8, which has built in GPS. On PC use RaceRender to import video file and it finds and extracts GPS data from the video file. Data is synced to video but I have found it to still be slightly off, but easily fixed in the software. Overlay done
This year I bought SoloStorm and run that on a tablet in the car. It can do overlays, but I'm having trouble getting it to control and sync to my GoPro. It's a lot of work but I can copy video file over to the tablet to do the overlay. I sometimes do that for my fastest run.
Overall RaceRender is super easy, fully customizable, and is free for short videos (<3min).
282
301
Virginia
The last event was in the rain and the car was making the noise a lot. I'm now leaning towards it being a pulley bearing. Although I have started acquiring parts for the electric power steering, so I'm still going down that road. But the fix might be cheaper than I initially thought. I have replaced all of the pulleys in the last 2 years, so it is a bummer if it is actually a pulley.
I can't get it to make noise all the time especially at idle, so it's been difficult to troubleshoot.
6,620
8,309
282
301
Virginia
Been slacking on updates. Currently in the process of installing an electric power steering column from a Prius and manual steering rack. More details to come once I finish.
It's going to be tough but I want to learn left foot braking. But the clutch pedal is so high compared to the brake pedal. Luckily Maximum Motorsports makes a clutch pedal adjuster. I also put a spacer on the end of the throttle cable at the pedal to raise it up off the floor some. I think that will really help Ashley as she has to stretch to push the pedal 100%.
While checking random things I found a metal like sludge on the rear axle magnetic plug. Checking the differential it is...I didn't find any chunks of metal but the differential could move some when I pulled on it. Going to replace the bearings and reshim. The car has a discontinued autocross specific Auburn diff.
Oh did I mention I have less than 1 week until I head to UMI Motorsports Park for Muscle on the Mountain autocross. I'm the only SN95 mustang. The next newest mustang from my 1994 is a 2013.
Cumming
What kind of details interested in? I have several build videos on my YouTube channel.
I've been watching them although without an extensive suspension background coming up with the exact locations for modifying the k member and such. I've been looking at the Griggs setup vs your all in spend video would you do custom had it over again?
282
301
Virginia
I did a video on the cost comparison. Although I have spent over $5000 and have had to do some redesign that is still considerably cheaper than Griggs or Cortex. Plus the learning experience and knowledge gained would not be there if I just bolted on a premade design. But the premade design is designed to work, while I have had to figure some things out. In the end I would do it again.
As far as the k-member, I modified to save money. If I had the money at the time and maybe in the future I would go with a maximum motorsports k-member. Like the MM my k-member pickup points are just raised 1" in position 1 and 2" in position 2. The k-member modifications are really easy. It's figuring out the placement of the upper arm is where you need a design program.
6,620
8,309
Its been fun following along. :D
